› Forums › IoTStack › News (IoTStack) › Smart Analysis Using Live Usage Statistics [SALUS]
- This topic has 1 voice and 0 replies.
AuthorPosts
January 18, 2020 at 3:13 am #38886
#News(IoTStack) [ via IoTGroup ]
Headings…
Share
Embed the widget on your own siteAuto extracted Text……
A Sigfox centered smart solution allows various manufacturers and third-party vendors to carry out usage analysis and customer level satisfaction index of their products autonomously.
In addition to standalone operation for multiple years, the solution comes with all the advantages of Sigfox including low cost and low power, portable and compact.
Sigfox is an LPWA (Low Power Wide Area) network that allows objects to communicate to the Internet for years because of its very low battery consumption.
MKRFOX1200 is a powerful board that gives the functionality of the Zero but the connectivity of the SigFox network.
The Sigfox module is given a unique user code to identify the particular housing unit or area where the energy consumption has to be measured.
The power consumption will be monitored with the help of a convenient current sensor interfaced using the analog connection.
The energy consumption data, the unique user code and the location (fixed for each device) of the module will be uploaded to the Sigfox network periodically.
The whole area under consideration will be divided into cell blocks inside the Sigfox network for easy management of data as shown below.
The AC current passing through the load is sensed by the current sensor module and the output data from the sensor is fed to the analog pin of the Sigfox module.
The calculated energy is then published to the Sigfox network.
Real Power = Voltage (V) x Current (I) x cosΦ
Reactive Power = Voltage (V) x Current (I) x sinΦ
Apparent Power (S) : It is defined as the product of the Root-Mean-Square (RMS) Voltage and the RMS Current.
Apparent Power = Voltage (V) x Current (I)
The products are shipped with a module consisting of a Sigfox based Arduino MKRFOX1200 module.
The module will monitor the usage of the products and sends the statistical data periodically to the Sigfox cloud using the same interface
Read More..
AutoTextExtraction by Working BoT using SmartNews 1.02976805238 Build 26 Aug 2019
AuthorPosts
- You must be logged in to reply to this topic.
